Oil type for 2000 xk8 ?
Old Jul 17, 2015 | 04:31 PM
plums's Avatar
Originally Posted by dannyXKR
the manual says 5W30 ... point
No it does not. Read the whole page, including the
chart and the fine print ... point.
Old Jul 17, 2015 | 05:42 PM
Mikey's Avatar
5W30 for the win
Old Jul 17, 2015 | 10:41 PM
plums's Avatar
Originally Posted by Mikey
5W30 for the win
Seems to me that there is a bar on the chart showing xW40
just as prominently as xW30 ... and with a wider temperature
range to boot.
Old Jul 18, 2015 | 12:21 AM
Mikey's Avatar
Yes there is, but a post above denies the mention of 5W-30..............
Old Jul 18, 2015 | 03:33 AM
plums's Avatar
Default life beyond xW30
BMW M variants specify a specific Castrol 10W60
Mustang Cobra's specify a 5W50
.... and Aston Martin models employing the Jaguar based V8 require Castrol 10W60.
Owners in the US are buying the BMW oil because the specific AM Castrol sku is not
available in North America. Same base design and forgings, completely different oil
specification from Jaguar. Bear in mind that the home territory of Aston Martin is
far more temperate than Atlanta.
Two sets of engineers, one engine design, two wildly disparate oil specifications.
So when someone says "the engineers know best", it is important to ask which
engineers, how much influence they had in the published materials, and what
was their goal.
Any particular engineer might know very well what and why he said something.
The problem for the reader is the why.
If the why is CAFE, well the guidance is of no real use vis-a-vis engine protection.
Once again,
https://www.jaguarforums.com/forum/g...luence-144787/
Old Jul 18, 2015 | 11:16 AM
stetson1's Avatar
why so complicated ... oil seems to be a quite difficult theme ...
So use what the manual says ... buy Mobil1 or Shell
Using new kind of oils isn´t so clever because you have to notice, that the engine is developed quite a few years ago. Jaguar knows, whats best for the XKs.
hmmmm, you mean 'knows what's best for xk's'...as in PLASTIC CAM CHAIN TENSIONERS, WATER PUMPS, 1/4WINDOW REGULATORS and some other brilliant parts/components, etc,etc?!!!
is that kind of 'know how' you're referring to?!!!
ok.
Old Jul 18, 2015 | 10:21 PM
plums's Avatar
Thumbs up
ok.
brilliant riposte.
Old Jul 19, 2015 | 08:17 PM
  #28
magnum454's Avatar
Default oil
I have a 2000 xk8 4.0 and I use Amsoil 5-30.
Old Jan 7, 2016 | 12:58 PM
cyber3d's Avatar
For anyone wanting to educate themselves on engine oil grades I found an interesting article that is pretty detailed. Good read.
Motor Oil Viscosity Grades Explained in Layman's Terms
Old Jan 7, 2016 | 05:01 PM
  #30
White Bear's Avatar
Best advice I can offer is use Mobile 1, 10/40 if your engine is quiet on it. If it has a slight tapping at idle then more than likely the VVT cam drive is a little worn, so change to 10/30 or 10/40 dynasuar oil, that'll help damp down the noise.
I personally believe. "Plums" has a valid point. Jaguar oil viscosity recommendations are more about fuel mileage and meeting Cafe regulations than engine protection. Note the more knowlegeable cognoscenti have recommended heavier oils than the OEM, up to and including 20/50, which was the gold standard for many years for high performance engines.
Regards,
Old Sep 11, 2024 | 05:39 PM
  #31
T Paolucci's Avatar
Originally Posted by bcucharternet
I recently purchased a 2000 XK8 and would like to change the oil. What is the best type of oil to use on a 2000 4.0 engine ? I have heard mobile 1 5-30w but have also read to use mineral 15-40w. I live in Atlanta, GA.
Thank you
bcucharternet
I have the same vehicle asking the same question, and getting many different answers.
I just got off the phone with Jaguar Customer service (800)452-4827 . They looked it up and told me to use 5W30 Mobil 1 or STP FULLY SYNTHETIC.
This agrees with what Is recommended by at least one of the local (Monterey Ca.) Shops and is what I have used in the past.
Tom
Old Sep 12, 2024 | 04:59 AM
  #32
RichardS's Avatar
Tom
A rather old thread .... but everyone loves an oil thread.
The official Jaguar recommendation is 0W-30, 0W-40, 5W-30 (preferred) or 5W-40 so it's pretty much an open field for any branded synthetic.
Richard
stanjag
Dec 29, 2024 08:26 PM
MJ'S Jag
Nov 10, 2022 08:14 AM
nelsonht
Aug 30, 2015 06:01 AM
peterg19
Aug 28, 2015 08:42 AM
Will P
Aug 27, 2015 06:52 PM
