Ok to add 1 quart regular oil to synthetic?
Old Apr 25, 2016 | 09:03 PM
Johnken's Avatar
Default Ok to add 1 quart regular oil to synthetic?
Opps can't edit headers iol = oil.
I should know this but can't remember and figured I'd ask a quick question.
Last oil change got Mobil 1. Just looked she is down a quart. I have nonsynthetic in my garage no Mobil1 around. Is it OK to put a quart in for another 2,000 miles?
John
Old Apr 25, 2016 | 11:05 PM
Kevin D's Avatar
Yes, you can. In fact, they even sell semi-synthetic, which is a mix of the two.
Old Apr 26, 2016 | 09:22 AM
Mikey's Avatar
There's no requirement to use synthetic oil in your car at all.
Old Apr 26, 2016 | 02:44 PM
brgjag's Avatar
I have always done this for ages with my cars that use a little oil before the next change, I might throw in it what ever is laying around.
As for my nicer cars, I ALWAYS use Mobile 1.
Old Apr 27, 2016 | 01:15 PM
Originally Posted by Johnken
...... Last oil change got Mobil 1. Just looked she is down a quart. I have nonsynthetic in my garage no Mobil1 around. Is it OK to put a quart in for another 2,000 miles?
An observation rather than a reply.
Neither of my previous 4.0 litre Jaguars (2000 XJ8, 2001 XK8) or 4.2 litre (2005 XK8, and current 2007 XK) have used any significant oil between changes.
A US quart (0.95 litres) seems a lot to use in 10k miles. Even more so if you do your changes on a time rather than mileage basis.
Old Apr 27, 2016 | 02:09 PM
brgjag's Avatar
I have owned some cars with 100k plus on them and they would use a quart every 4-6k miles. My current Jag uses non at 104k.
Old Apr 28, 2016 | 06:34 PM
Cosmo2020's Avatar
I came the Forum today to find out whether I should use regular or synthetic oil. I tried to find out from the previous place the owner had taken it to with no luck 2003 Jaguar XK8. I called a Jaguar dealer and they said just use 10-30 motor oil which surprised me. Can anyone look or feel oil to see if it is synthetic or not ? Anyway went and got a regular change and lube job as well. I wanted to know what the previous owner was using because...wait for it... my car just hit 183,000 miles !!!!!!
Old Apr 28, 2016 | 07:15 PM
Mikey's Avatar
This agrees with whats in your owner's manual. Many people want to turn the subject into rocket science.
Old May 1, 2016 | 03:46 PM
GordoCatCar's Avatar
.... I'm @ 97K miles and thanks to Nikasil liners it uses no oil between changes.
Old May 2, 2016 | 06:49 AM
jamdmyers's Avatar
John
Maybe just drive 5 miles and pick up a qt of synthetic then drive as long as you like ?
Old May 2, 2016 | 07:51 AM
Last oil change got Mobil 1. Just looked she is down a quart. I have nonsynthetic in my garage no Mobil1 around. Is it OK to put a quart in for another 2,000 miles? Thanks John
Hi John: Yes it is OK to mix the two and double check this fact I went to the internet authority on oil... Bob the Oil Guy.... Safe to mix Synthetic/Conventional Oil? | Passenger Car Motor Oil (PCMO) - Gasoline Cars/Pickups/Vans/SUVs | Bob Is The Oil Guy ... All of BTOG members say no problem.
Snookfever
Nov 13, 2019 07:53 PM
user 84302
Sep 29, 2016 08:54 AM
NJ2003XJ8
Apr 27, 2016 09:08 AM
brinny
Apr 23, 2016 08:44 AM
daves_ale
Apr 20, 2016 08:45 AM
