Oxygen sensor. Same or different ?
Old Mar 4, 2023 | 03:18 AM
Pistnbroke's Avatar
Default Oxygen sensor. Same or different ?
Being a kind of 7Ps person I am looking into oxygen sensors should the day come ....The advertising is confusing.
Front sensor /fitment rear WTF does that mean? prices from £10 to £100. Are the 4 the same or two pairs of two?
Amazon quotes two for £20 being
  • OEM Reference Number : 2R839G444AC, C2C1238, C2C8442, LNE1682BB, C2S38497, LNE1682BC C2C7360, C2C25956, 2R839G444AC
So someone with knowledge on this give me the low down.
Old Mar 4, 2023 | 11:14 AM
NorXKR's Avatar
There are 4 oxygen sensors. 2 before catalytic converters (often called upstream) and 2 after (downstream) That means it is two pairs of two.
I strongly suggest you go for the OEM Denso brand. Some cheap generic will just give you trouble.
Aarcuda's Avatar
So if you have a V6 or a V-8, you have two exhaust pipes coming off the engine. One for bank one and one for bank two. On each bank, you have a catalytic converter. You will have one 02 sensor in front of the catalytic converter between the catalytic converter and the engine and then a second O2 sensor either in the center of the catalytic converter or after the catalytic converter, but you normally have them in the center of the cat on Jaguars
The two o2 sensors are different and will have different connectors as well as different connector colors. For example, one may be white and one may be grey. They cannot be swapped. You can swap them from side to side (bank to bank) but they need to be put in the same position they came from so the front O2 sensor must go to the front on the other bank if you’re going to swap them, but you can’t swap a front O2 sensor for a rear O2 sensor. They are different types of O2 sensors.
Old Mar 4, 2023 | 03:08 PM
fmertz's Avatar
Also, remember the front sensors are wideband sensors (they detect oxygen over a wider range of concentrations), and the rear sensors are the older lambda style (they only detect oxygen accurately around stochiometric). The control circuit for measurement is also completely different. They are not interchangeable. As already pointed out, Denso sensors have proven pretty reliable.
Best of luck, keep us posted.
Old Mar 5, 2023 | 01:01 AM
Pistnbroke's Avatar
Thanks guys ..anybody got the part numbers for the front and rear?
done some research and
Down stream has Black plug C2C25956
upstream is grey C2C 7359
The prices are all over the place from £10 to £100
Next time I am under there will check how bad the access is !
Old Mar 5, 2023 | 05:15 AM
michaelh's Avatar
There are no rear/lower/downstream sensors on the early non-US spec XK8s. Just a blank boss in the cat.
Heritage shows LJA1682AE as the part # for the uppers, but the price is....
Old Mar 5, 2023 | 12:02 PM
Pistnbroke's Avatar
mine was made very early 97 so I will look into that ,
Old Mar 5, 2023 | 03:29 PM
michaelh's Avatar
My 98 doesn't have them either. Things changed with the arrival of the AJ27 motor for MY99 (XK8)
I should have been more specific.
Old Mar 5, 2023 | 06:17 PM
NorXKR's Avatar
Search for Denso DOX-0430
Old Mar 6, 2023 | 01:17 AM
Pistnbroke's Avatar
Hope you are right michealh as it means I only have to buy/carry one as a spare for my continental trips.
thanks Norxkr
Old Mar 6, 2023 | 01:35 AM
Defender99uk's Avatar
Try Eurocar parts, I found them to be cheapest in uk for the Denso ones
Old Mar 6, 2023 | 01:40 AM
Pistnbroke's Avatar
Best price I could find was £55 and the worst £1000 Most seem to be about £100.
So it seems if you have a single o2 sensor then its a different number to the top one on a double 02 sensor system.
Old Mar 6, 2023 | 06:19 AM
michaelh's Avatar
Originally Posted by Pistnbroke
...and the worst £1000
Ridiculous. Was he wearing a long black coat & face mask?
Even Heritage is only about 1/4 of that:
https://parts.jaguarlandroverclassic...en-sensor.html
From JEPC:
031303 is MY99 intro
Old Mar 6, 2023 | 07:58 AM
Pistnbroke's Avatar
Mine is 12041 certainly a 97 so I think I need eyes on it,
Traveller
Feb 27, 2020 10:13 PM
kurtomatic
Oct 23, 2015 11:57 AM
redzed
Jan 16, 2010 11:29 AM
