P-zero system tires?
Old Oct 5, 2013 | 06:40 PM
JaguarXKR's Avatar
Default P-zero system tires?
Hi, I was wondering are they still making these tires for our cars? I can't find the matching set that came as the original equipment tires. I want to keep the car original, so don't want to reply with regular p-zeros. Any leads?
Thanks.
Old Oct 5, 2013 | 07:17 PM
I can't help with a US supplier but can confirm that Pirelli P ZERO Asimmetrico 245/50 ZR17 99Y are available in the UK so they are definitely still being manufactured.
Old Oct 6, 2013 | 01:51 PM
Sentinelist's Avatar
What's the difference, for the record?
Old Oct 6, 2013 | 05:34 PM
According to Pirelli, the benefits of 'Asimmetrico' are:
An asymmetric design that responds both to the need for increased levels of safety and enhances the performance of the car. Precise in the dry and resolute in the wet, P Zero™ maintains remarkable consistency between its static and dynamic footprint. An active structure that responds to rolling stresses without transmitting tension through to the steering wheel, even at high speed. Compounds that react immediately, guaranteeing the same high degree of performance from cold as when the tyre is up to temperature. A new tread pattern ensuring durability and consistent performance throughout the life of the tyre.
Features
1. asymmetric tread design with superior handling and braking characteristics
2. New high-grip compound
3. High aquaplaning resistance
4. Improved structural stiffness for high performance driving and integrity
There has to be something to justify the cost!
Old Oct 7, 2013 | 01:31 AM
xenophobe's Avatar
I'll say that the tread pattern of the Hancook V12 is nearly identical to the Michelin Pilot Sports.
The Pirelli P-Zeros are nice, but not worth twice the price.
There are more than 3 different ZR rated tires for half the price of the PZ's. I guess if you drive like a granny, it doesn't really make a difference. If you drive aggressively, you'll wear out those P-Zeros quickly. I wore my fronts out in less than 10k miles.
Old Oct 7, 2013 | 05:24 AM
smithtrevor's Avatar
Aviod Pirelli full stop !!! There is a write up on the Jaguar UK Forum under XK / XKR 1999 - 2005 MY entitled "which tyres" a real horror story with poorly built tyres from this manufacturer.
smith356
Oct 7, 2015 06:41 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
johndahlheimer
Sep 16, 2015 05:44 PM
Armor6
Sep 14, 2015 07:56 PM
Armor6
Sep 10, 2015 12:08 PM
