P0171 and P0174
Old Nov 18, 2021 | 12:13 AM
Retiredsailor63's Avatar
Default P0171 and P0174
Yep I got the codes, CHeck engine light, and reduced performance displayed. I thought it was the MAF sensor cleaned it, no change. Started to look closer and low and behold the cold air duct from air filter to throttle body right at the flexible corrugated plastic, was failing. I touched it and it crumbled. I did a temporary duct tape repair. Reset the code, drove 20 miles and no check engine light Ive ordered a replacement duct. Sometime its just that simple.
Tony
2004 XK8
102,000 miles
Old Nov 18, 2021 | 01:47 AM
ozbot's Avatar
I replaced mine with the Mina aluminum version for this very reason. Here's what it looks like on my '97 XK8.
Old Nov 18, 2021 | 06:16 AM
Jon89's Avatar
Yep, Mina is the way to go. I installed one in April 2019 after the second OEM plastic duct began to crack at the accordion pleats after just six years. The Mina solution is final, and I like that....
Old Nov 18, 2021 | 07:57 AM
David Dougherty's Avatar
Default Any difference?
Just curious did it make any difference in sound or performance ?
Old Nov 18, 2021 | 10:06 AM
Jon89's Avatar
None that I can tell. Mina likes to tout a slight increase in horsepower but I remain skeptical. I did it solely for the permanence....
mhessen6
Feb 15, 2016 11:46 AM
DevSpider
Dec 22, 2014 12:50 PM
pingj
Aug 2, 2013 06:06 PM
lylon
Mar 10, 2010 08:07 AM
Sparkers69
Oct 25, 2009 05:10 PM
