P1260 Security Problem= Car will not Start
Old Aug 13, 2020 | 11:15 AM
djpxk8's Avatar
Angry P1260 Security Problem= Car will not Start
Cannot start my 2001 XK8, when I put the key into the ignition all the indicators on the dash light up, but when I turn the key to start the car ...Nothing!
1. So far I have fitted a brand new Battery, charged to 13.6V.
2. Lock the car with the key at drivers door then went to trunk and opened with key only....car alarm goes Off!
3. On the battery, Disconnect both positive and negative terminals touch both together for 5 minutes put they back on battery go to start the car...Nothing!
4. Check voltage levels, buy new battery, charge overnight gives 13.6v
5. My "Indie" is now suggesting it could be the "Exciter Ring" which reads the chip in the key??....is this a likely solution??....ANY OTHER SUGGESTIONS WILL BE MOST WELCOME!
Regards, David
Old Aug 13, 2020 | 11:37 AM
bladerunner919's Avatar
Have you got another key that you can try?
Old Aug 13, 2020 | 11:47 AM
fmertz's Avatar
This: dreaded-p1260-fault-code-216780
This:stolen-car-93319
Best of luck, keep us posted.
Old Aug 13, 2020 | 04:49 PM
djpxk8's Avatar
Yes I have tried both of my keys...thank you
Old Oct 10, 2020 | 09:19 PM
djpxk8's Avatar
Smile P1260 Security Problem= Car will not Start
Solved the problem, had the car towed to the Jag dealer in Orlando and for $125 they reprogrammed the key and the car now starts!!
Old Oct 11, 2020 | 09:40 AM
motorcarman's Avatar
I have seen cars that just 'FORGOT' the configured keys.
Must some queertronics going on?
hemitwist
May 12, 2024 04:11 PM
mchums
Dec 12, 2018 01:41 PM
emaraszek
Jan 29, 2014 10:40 AM
Ziggy122
Feb 28, 2013 07:50 AM
topherscott
Oct 8, 2011 08:12 PM
