Pandora is being a hardass
Old Apr 2, 2022 | 08:51 AM
olphart's Avatar
Default Pandora is being a hardass
I noticed that the ride seemed kinda harsh, so I pushed down on the corners of the car to check shocks/springing. Fronts were fine, but the rear barely moved with my full weight. My guess is bushings?
Any other thoughts?
Old Apr 2, 2022 | 12:20 PM
olphart's Avatar
The mechanic suspects shocks
Old Apr 2, 2022 | 03:16 PM
zray's Avatar
The rear end of my ‘02 XKR does
not push down as easy as the front either. By itself, that does not indicate a fault. My car handles well for a 4,000 + lb car. At high speeds the rear springs and shocks seem very compliant to road conditions and give a firm GT ride. I wouldn’t want it to be more soft.
The front of the car has the weight of the engine “helping” you press down. In comparison the rear is pretty light.
Z
Old Apr 2, 2022 | 04:21 PM
drmike's Avatar
I thought at rest CATS were in firm mode so you wouldn't expect to bounce the rear end.
Old Apr 3, 2022 | 07:15 PM
oldmots's Avatar
Bushings are not the issue. Most likely, what you have is normal. Even if the bushes were welded to the frame, the shocks would still go up and down.
Old Apr 3, 2022 | 07:20 PM
olphart's Avatar
My mechanic says the same, basically "Get over it"
elithrift
Aug 1, 2015 06:36 PM
coastaljag98
Oct 3, 2013 06:35 PM
kurtomatic
Oct 21, 2012 02:32 AM
jjones91
Jul 8, 2009 05:22 PM
