Passenger seat.....
Old Apr 8, 2014 | 05:37 AM
RSsteveH's Avatar
Default Passenger seat.....
Has stopped working. No electrics of any sort. I'm wondering what it could be. Fuse? Or something. The back was put down a bit hard on one occasion just before it stopped working - so something could be broken?
If anyone has any idea or a pointer in the right direction, it would be most appreciated.
Old Apr 8, 2014 | 05:53 AM
The Seat Module could have been damaged or one of the harness connections come adrift.
The Seat Module is a regular issue. The lids (available separately) break and the circuit board can get cracks in the tracks from flexing in use.
Old Apr 8, 2014 | 06:27 AM
kreyszig's Avatar
Also, the insulation on the electrics under the seat get worn and blow a fuse. If this is the case then the heated seat and powerfold mirror on that side (iirc) will stop working as they share the same fuse.
My driver's side has this problem, if you drop the seat too far the cables short. One weekend I'll remove the seat and shrink wrap the cables.
The fusefor the drivers seat is on the drivers side (UK RHD), I'm not sure from memory if there is a passenger side box or whether both fuses are in the same box.
Old Apr 8, 2014 | 10:07 AM
RSsteveH's Avatar
Thanks for this - the mirror still still works so I guess this rules out the fuse. The seat did come down quite hard so I'll check to see that the connector hasn't just popped out.
Thanks guys
PS Swansea boy huh? I'm Pembroke born and bred although in London working and living now.
Old Apr 9, 2014 | 03:33 AM
kreyszig's Avatar
Thanks guys
actually i'm a kiwi that couldn't resist the bright lights of Swansea :-)
I try to get out to Skomer now and then, yet to take the Jag down, it should be bliss!
1983turbojaguarxj6
Jan 11, 2025 10:28 PM
hoodun
Nov 20, 2022 02:35 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
JagBrian
Oct 1, 2015 12:52 AM
