Passenger Seat Module 2002 XKR
Old Jul 30, 2011 | 08:19 PM
Captain Kana's Avatar
Default Passenger Seat Module 2002 XKR
I have a couple of issues with the passenger seat module in a 2002 xkr.
Someone had stuck it back under the seat with velcro. I am able to correctly install with the 10mm nuts, but I noticed it has three plugs in the back, and only the left and right are used. The center is empty? The module is also has a date of 2004 on it. I guess it was replaced.
The drivers side module uses all three plugs (by the way, it was zip tied in, someone had broke it removing it and I am in the process of fixing it so it bolts back).
Also, as mentioned in an earlier post, the headrest does not go up and down, but you can hear the motor. Any ideas?
Thanks Dan
Old Jul 30, 2011 | 10:22 PM
H20boy's Avatar
Hey dan, the headrests are classic symptoms of the cable sheath being too long. Go to the faq page in this subforum, and find the link to pics, threads, and the reverend sam made a video also, for your viewing pleasure. We've all done the headrests.
Old Jul 30, 2011 | 10:29 PM
WhiteXKR's Avatar
The seat module lids are available from the dealer and inexpensive (see attached TSB).
I also attached the headrest TSB.
File Type: pdf
File Type: pdf
Old Jul 31, 2011 | 10:35 AM
Thank you all for the reply and directions.
Dan
GordoCatCar
Jan 2, 2017 01:10 PM
Dicque
Sep 19, 2015 12:53 PM
avern1
Sep 8, 2015 06:25 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
bdboyle
Sep 4, 2015 06:16 AM
