Passenger window won't seal
Old Jan 28, 2018 | 01:01 PM
Salu498's Avatar
Default Passenger window won't seal
Passenger window won't completely seal when door opened and then shut. Stays about an inch open!
Old Jan 28, 2018 | 01:18 PM
Jon89's Avatar
How old is your battery? Window open/close issues are one of the first signs of a failing battery....
Old Jan 28, 2018 | 02:01 PM
frankc's Avatar
Common problem. Very easy fix.
Sit in car. Door shut. Key in ignition. Turn the key to the position just before starting, 2nd position? Dont start the car.
Do both windows at the same time.
Push the button/s to make the windows go all the way to the bottom and HOLD button down till you hear a faint click (usually around 5 seconds after getting to limit)
Then push the windows up button and when they both get to the top HOLD again till you hear the faint click.
Job done. Told you it was easy.
Let us know how you got on wont you?
Old Feb 1, 2018 | 04:52 PM
frankc's Avatar
Did you try it? Did it work?
Old Feb 1, 2018 | 06:06 PM
Salu498's Avatar
I think it worked. Heard both clicks, but haven't had chance to verify.
Old Feb 3, 2018 | 10:35 AM
frankc's Avatar
Great, glad you got it sorted.
nd4spdlsc
Nov 26, 2019 07:43 PM
XJsc-guy
May 23, 2017 02:46 PM
Anthony8858
Jul 30, 2016 10:07 AM
gthawk1
Jun 10, 2014 06:25 AM
Chaz17
May 6, 2012 10:09 PM
