passengers window has a mind of its own?
Old May 5, 2012 | 04:25 PM
deadboy1977's Avatar
Default passengers window has a mind of its own?
I am charging my battery now, the battery is a year old....
Drivers window is fine but passengers will lower on its own will while driving
When it goes fully down, if i hit the passengers UP button I hear the click but thats it, it doesnt go up....if I try it a few minutes later it may or may not go up (I always hear the click...I reset the window stops too (up and down) to no avail...ideas??
Old May 5, 2012 | 06:16 PM
Gus's Avatar
Gus
The window dropping when driving might be another issue not related to the battery. The door latch has several switches and the mechanism is often overlooked and never lubricated. Take a little WD-40 and spray it into the latch area and be sure not to overdo it and work the door several times. Give it a day or two before you replace the battery.
Old May 5, 2012 | 06:19 PM
test point's Avatar
Battery problem!
The window lift circuit is a 30A fused circuit that is dragging the battery voltage down below the appx 10v minimum of the electronics.
The battery voltage could be a symptom of corroded high current connections of failed/failing alternator diodes.
Old May 7, 2012 | 06:00 PM
well battery is fully charged and i lubed the latches and worked the passengers side like 20 times opening and closing to no avail...drivers side has no problem, new ideas?? Battery took a full charge and is only a year old so I doubt its the battery??
Old May 7, 2012 | 07:30 PM
Gus's Avatar
Gus
Swap the door control module with the driver’s side to see if it is the problem or one of the switches in the door latch mechanism. Link http://jagrepair.com/images/AutoRepa.../jagxk1999.pdf page 20 the same on your 2003
99xk8guy
Sep 29, 2025 10:51 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
avern1
Sep 8, 2015 06:25 PM
