Passive security handshake
Old Aug 28, 2024 | 11:41 AM
johnbblagard's Avatar
Default Passive security handshake
hi all.
im trying to fix a no crank no start fault. On my 2004 coupe xk8. My question is
when the key is in the ignition on (run position) and the fuel pump is running, can I assume all of the security handshakes with the key have happened and the car is ready to proceed to the start/crank position?
thanks for any help.
Old Aug 28, 2024 | 01:44 PM
motorcarman's Avatar
If you have the correct 'recognized' key, it should start.
An INCORRECT key (or unrecognized RFID key) will flag a P1260 DTC.
Old Aug 28, 2024 | 02:52 PM
michaelh's Avatar
Originally Posted by johnbblagard
...can I assume all of the security handshakes with the key have happened and the car is ready to proceed to the start/crank position?
Frayed knot. ^^What motorcarman said.You need the car to tell you what it thinks is wrong (DTCs).
It won't crank unless all the security prerequisites have been satisfied.
Is there a history here of some work done prior, or did the car just decide not to play?
Old Aug 28, 2024 | 05:27 PM
Thanks for the replies. They seem a little ambiguous. Please allow for my poor question. I was hoping for a definative yes or no answer. Prior to putting the key into the crank position. Can I please rephrase it.If all lights, etc and the fuel pump is running, can I assume that all passive security measures have been met?
Old Aug 28, 2024 | 07:15 PM
NO
It will flag a P1260 DTC and NOT START.
Old Aug 29, 2024 | 04:33 AM
Thank you. Thats the clarity I was hoping for.
I will now look for the code you kindly provided.
onewhippedpuppy
Mar 20, 2023 05:58 PM
Markmbaha1
Jul 7, 2022 11:44 AM
tsuppari
Apr 15, 2021 06:54 PM
jmfowler
Jul 26, 2019 10:51 AM
geberhardt
Sep 24, 2014 01:10 PM
