Petrol tank pressure
Old Aug 10, 2014 | 10:51 AM
NobbyXKR's Avatar
Default Petrol tank pressure
Hi Guys
I have an issue with my 1999 xkr.When I fill up with petrol ,most times when I remove the filler cap. there is a sudden out rush of air really quite forceful.I have to remove it slowly or I think it would blow the cap out of my hand.It seems worse when I have been on a long run and on a hot day.It hasnt always done it but takes me by suprise when I take the cap off.Is there a breaher hole in the fuel system somewhere that could be blocked?
Old Aug 10, 2014 | 12:40 PM
ccfulton's Avatar
The system should vent through a charcoal canister and is plumbed to the intake manifold through a valve. When driving the valve will periodically open to pull the fumes out of the canister and this also lowers the pressure in the tank to prevent what you are experiencing.
You might have a problem with the vapor recovery system or the canister close valve (CCV). These should give you some kind of code and potentially a check engine light. Have you checked if the ECU has logged any error codes?
Old Aug 11, 2014 | 02:49 PM
NobbyXKR's Avatar
I dont have any way of checking for error codes and there has been no engine lights come on.Do you think this could cause me any problems or danger to the engine?
Old Aug 11, 2014 | 06:00 PM
ccfulton's Avatar
Probably not to the engine, but I suppose it could damage the tank or some of its seals.
If a tank is not venting properly I have heard of the fuel pump pulling enough vacuum that the tank collapses.
Old Aug 12, 2014 | 02:50 PM
NobbyXKR's Avatar
this is my dilema the air rushes out not in so the tank is being pressurised!
Poet
Feb 7, 2025 02:18 PM
bdboyle
Sep 16, 2019 05:58 PM
ryan_border
Dec 23, 2015 04:27 PM
reb1999
Sep 25, 2015 10:00 AM
hen555
Sep 7, 2015 11:13 PM
