Ping-clunk from rear suspension
Old Jun 26, 2015 | 02:29 PM
looops's Avatar
Default Ping-clunk from rear suspension
Hi all.
Tearing my hair out here. I'm getting a ping-clunk sound from the rear or maybe a bit toward centre when I go over small bumps at low speed. I've changed the rear shock lower bushes and just now changed the rear drop links and has made the problem 50% better, how is this possible???
Any thoughts or suggestions?
Paul.
Old Jun 26, 2015 | 03:01 PM
batroute's Avatar
Upper rear shock mounts would be my guess, although no idea why the drop links replacement would make it better I have no idea.
Old Jun 26, 2015 | 03:04 PM
smoggyx100's Avatar
Also check your rear brake pads. I had the same issue and it was the inner pads rattling around as the mounting spring on the back of the pad breaks off.
Old Jun 26, 2015 | 03:59 PM
cyber3d's Avatar
When you had the assembly down dogs you check the shock itself? On a different car I had the initial damper was shot and I had the same symptom.
Mugatu
22
Jun 23, 2020 01:50 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
