Please Help. Battery and No Start
Old May 2, 2022 | 01:21 AM
Pistnbroke's Avatar
The inertia switch has a button at the top which must be pressed down fully...never know one to be intermittent but possible. Can get triggered by a big pothole etc
You could check if you have 12v at one of the live bolts near the LH under bonnet fuse boxes ...a bulb is better than a digital meter..headlamp bulb would be perfect.
Note to the wise ..."get misled use a digital voltmeter"
Old May 2, 2022 | 02:19 AM
drmike's Avatar
Originally Posted by zray
are engineered to have a 10 year lifespan. We are now going on twice that. Circuits corrode. Connections get cranky. The full battery voltage may not be getting thru to critical components.
I guess you're right, I must be blessed that so far few if any electrical gremlins have crept into this car, nor into my previous XJ6, nor my 1974 Range Rover but of course I am aware of others having many problems as I did with a Citroën CX2500 which failed due to corroded spade connectors and that was probably about 10 years old. It was however, French. Great but flawed car.
Old May 2, 2022 | 02:37 AM
Pistnbroke's Avatar
Electronics on a 74 Range Rover ..I think Not. Wish I still had mine they are worth a fortune.
The bit that fails is the electrolytic capacitors drying out.
Old May 2, 2022 | 02:42 AM
drmike's Avatar
Sorry, of course the most complicated electronics the RR had was that terrible electronic ignition which I suspect came with a retro fitted V8. Amazingly I was grumbling to a friend that I couldn't get it to work properly and it turned out he was on the development team for it and he put me on the right track. Mine was a pure off road car, bob tailed, lifted a bit and a load of smaller changes. Painted NATO matt black - some sort of paint that reduced detection which couldn't possibly have worked. But cheap and could be applied with a roller.
Old May 2, 2022 | 02:45 AM
Pistnbroke's Avatar
OPUS Oscillating pick up system ...They were told to put the switch box in a cool air flow so they put in between the banks of the V 8 been there done that ....
Old May 2, 2022 | 06:42 PM
Oak's Avatar
Oak
Thank you
I did get the car running. I believe it was battery voltage
Battery was fine. Battery tester showed 12.2 bolts and 745 cold cranking amps. Wouldn’t start. Put a jump box on it and it started. Since then it’s started several times on its own fine.
Old May 2, 2022 | 08:52 PM
RJ237's Avatar
12.5 is probably the minimum. But if it draws down below 12 when cranking that's too low
Old May 2, 2022 | 09:21 PM
  #28
zray's Avatar
Originally Posted by Oak
Thank you
more ammunition for keeping the battery at full voltage / efficiency via a battery tender whenever the car is not being driven, overnight or longer.
One cannot treat a 20 year old car with miles of wiring like it was brand new.
Z
Old May 3, 2022 | 12:46 AM
Pistnbroke's Avatar
Sounds like a problem waiting to rear its ugly head again.. If you had dash lights and no start it could be a starter motor problem .. brushes/contacts just depends on where the starter stops.
Thermo
Sep 11, 2016 07:44 PM
tw5
Jul 25, 2014 06:52 AM
flyrr100
Nov 4, 2013 09:31 AM
SV8Predator
Apr 12, 2009 04:26 PM
christo
Apr 5, 2009 11:19 AM
