Please, need help - Transmission Cut-out
Old Jul 26, 2011 | 10:59 AM
Dmfinley's Avatar
Default Please, need help - Transmission Cut-out
Need some help! Driving my 2003 XKR steady about 40 mph when it lurched (bucked) for a split second. Kept going, about a minute later did the same thing, Acted like just turned the key off for a second. Noticed the Speedometer needle dropped like no power and then came back when car kicked back in. Then Transmission fault light came on. Pulled over, turned car off for a minute, restarted drove home fine, no fault light. Is there some speed sensor that is going back or perhaps a throttle position sensor?
Ran codes but showed normal on OBDII.
Would appreciate any thoughts before I go to shop.
Thanks, David
2003 XKR
Old Jul 26, 2011 | 12:38 PM
oldmots's Avatar
My first thought is a crank position sensor or throttle position sensor (as you thought)failing. Pull the codes to see if there are any hiding in there. If the ignition quit for a second, something may have logged.
Old Jul 26, 2011 | 01:27 PM
H20boy's Avatar
sounds familiar, like a recent thread of similar symptoms...can't place it though. IIRC, I mentioned throttle body...lets see if I can search my own posts...
It is from an earlier car, but lots of the electronics are similar, though the engine is previous gen and transmission is different.
Poet
Feb 7, 2025 02:18 PM
Marka
22
Sep 11, 2016 12:09 AM
dmatthewman
Sep 30, 2015 10:10 AM
Old_Doc
Sep 29, 2015 03:43 PM
