PO 171
Old May 5, 2018 | 07:21 AM
Rodkel's Avatar
Default PO 171
99 xk8. What steps to take to find the problem, if anyone has had that trouble code.
Old May 5, 2018 | 07:39 AM
JagV8's Avatar
Use P0171 and then you can use Search to see what to do.
Old May 5, 2018 | 11:53 AM
avern1's Avatar
As a new member you may not have reached the minimum post yet to have full access to do searches.
I have attached the definition for the P0171 code you are receiving. It also lists possible causes. I would first check the air inlet pipe bottom side for cracks in the convoluted area. A pretty common problem.
The most likely cause of the code is a vacuum leak allowing un-metered air into the system.
Chuck Schexnayder
Dec 21, 2016 11:10 AM
magnum454
Dec 29, 2014 08:19 PM
Bob Swaney
Oct 25, 2014 04:16 PM
Simon.h
70
Nov 25, 2012 06:56 AM
hunsi
17
Feb 15, 2012 07:07 AM
