Power Steering Leak
Old Sep 13, 2013 | 02:01 PM
Burdedw's Avatar
Default Power Steering Leak
I've had a small oil leak for the short time I've owned my 1998 XK8, and I've had to add Power Steering Fluid.
I got under the car today to check out where the leak is, and it appears that the pressure hose coming from the bottom of the P/S pump and going to the rack is leaking. It's a foam covered hose and the foam is worn in one spot and saturated with fluid.
Has anyone had the pleasure of replacing this hose?
It looks like nasty job, so I was hoping for some suggestions to make the job easier (if that is possible)
Thanks,
Dave B.
Old Sep 13, 2013 | 03:36 PM
lovemycar1's Avatar
I bought the hose of which you speak. But when I went to replace it, all that was wrong was the O ring that was in the conector at the attachment to the pump. I still have the new hose hanging in my garage mocking me whenever I go out there.
Old Sep 13, 2013 | 04:09 PM
Burdedw's Avatar
Lovemycar1,
I'd be pleased to take it off your hands and stop the mocking when you go in the garage.
Let me know if you want to part with it.
Dave B.
Old May 22, 2014 | 05:46 PM
shanxk8's Avatar
Hi there,
Do you happen to know the size of the o-ring for that fitting?
Thanks,
David
rusty37
Apr 5, 2020 07:40 PM
Dicque
Sep 19, 2015 12:53 PM
sogood
Sep 15, 2015 07:35 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
