Power steering leak, common problem?
Old Mar 15, 2014 | 05:39 AM
philhef's Avatar
Default Power steering leak, common problem?
Have to take my 2002 xk8 in for a power steering leak and wondered if this is a common problem. We tried to replace two gaskets but it didn't work and of course you can't just buy the problem hose, it seems it requires a whole new 218.00 assembly.
Old Mar 15, 2014 | 09:41 AM
tberg's Avatar
Phil,
Several months ago I developed a leak in the steering rack, bought a rebuilt unit and had it installed. It gushed fluid within five minutes of installation, and this happened 2 more times before we got one installed that didn't leak. Really pissed me off!
Attached Thumbnails Power steering leak, common problem?-dscf0524-1280x960-.jpg
Old Mar 15, 2014 | 03:52 PM
Bad Cattitude's Avatar
If you have a leaky hose, take it to a local hydraulic service repair shop. They should be able to fix/replace it cheaply.
Old Mar 15, 2014 | 04:15 PM
SteveJacks's Avatar
Search the forum for this...if it is leaking on the passenger side (US models) under the air filter box area, there is an inexpensive, do it yourself, reliable fix. I'm going on 2 years with zero leaks since I fixed mine. It involves cutting the fitting end off and using a barbed brass fitting in the hose end and a short rubber hose to the brass fitting and the other end of that sliding over the cut tube with clamps. There are photos and a write up on the forum somewhere.
toronadomike
Jan 22, 2026 10:13 PM
allenman85
May 10, 2021 03:11 PM
Russ Graber
Feb 23, 2019 11:59 AM
alpecsa
Sep 7, 2015 11:55 AM
dcvickers
Sep 2, 2015 06:14 PM
