Purchase advise
Old May 31, 2009 | 11:13 AM
skatsuf's Avatar
Default Purchase advise
I am considering the purchase of a 2005 XK8 convertible with 45,000 miles and am wondering if I should be concerned with the same issues of the earlier v8s such as timing chain tensioners or tranny repairs. I have a 99 xj8L with 40,000 miles and am familiar with early timing chain tensioner issues and nikilsil lining issues. Thanks Jim
Old May 31, 2009 | 02:43 PM
hlgeorge's Avatar
No engine issues with the 05 model. The only major issue that is with all the models is the hydraulic line leak at the top latch.
Old May 31, 2009 | 03:59 PM
skatsuf's Avatar
Default XK8 conv
Lew, Thanks for the reply. Any idea how much to fix this if repair is necessary?
Old May 31, 2009 | 05:47 PM
test point's Avatar
Eventually it will be necessary. You have to remove a lot of the interior to replace the lines. While that may appear daunting it really is only a number of simple things. Just takes time and that is why the dealers get $1200 - $1300 for the labor and parts. The two lines are only about $200 of that.
There are a couple private efforts underway to spec out much greater capability in replacement hoses. Check with Gus on his web site. http://www.gusglikas.com/autorepair.htm
H20boy
Dec 24, 2024 03:23 PM
captbob73
Oct 24, 2015 05:49 PM
axr383
Sep 12, 2015 01:32 PM
rsperle
Sep 12, 2015 08:37 AM
prettydaim
Sep 7, 2015 05:16 PM
