Question on Plastic Timing parts I just had replaced...
#41
Hate to say this...BUT
My tensioners fell apart and I had to not only replace all the chains, tensioners, seals, gaskets, and what nots, but I also had to remove one head, replace two valves, and all the seals and gaskets that went with that...AND replace the plastic thermostat while we were in there and I ended up at about $2K with $800 of that being the independents labor.
#42
Bravo...now start enjoying the fruits of your labor
Good job even if you had a long way around..... through no fault of your own
Aleather (09-03-2017)
#43
#44
In my option, he 'most likely' did a good job with what he replaced, but didn't have the timing tools to lock the cams in place to change the chains and didn't realize that changing the secondary tensioners, you don't need to lock the cams in place.
He had my car for two weeks and just wanted to be finished and get paid. So, he never let on about not changing the secondary tensioners and the next day I drove to New Jersey and back to Cape Cod (approx 600 miles) before I looked at the old parts and pictures he took; and posted the post on this forum, that lead me to do the rest of the job myself.
#45
#46
I personally thing the chains will last a lot longer and probably even beyond 100K. If they get too sloppy I would thing you would get some rattling at start up. I am going to have my primary rails and tensioners changed shortly but leave the chains alone at 64,000 miles.
You have to go through all that work just to get to the blades and tensioners, I really can't see the point of doing the job twice.
Once for the blades and tensioners and then again for the chains 'IF' they start to rattle?
Do them once, do them right, forget about them for years to come.
At your local indy that's two lots of labour charges for doing one job.
And we all know what the cost of labour is these days, even at the indy's.
#47
Received 2,292 Likes
Agreed that at 30K I expect that Aleather's chains will be OK - especially since the tensioners didn't lose their plastic caps so there's been no metal-to-metal contact with the secondaries.
I'm with stevep10 though if you have to go into the primaries anyway, the added cost of the chains is small compared to the PITA of having to do the job twice.
Just my
Just my
#48
#49
#50
Just spotted the missing piece on the chain guide 3rd down in your pic. I don't see any evidence of metal-to-metal contact on the edge, although is that a tiny piece of metal bent up on one side at the end of the groove? They're probably the least broken up set I've seen posted here, but they're much better in your dustbin rather than the car
The secondary tensioners haven't lost their plastic shoes, so that's something you won't find in your sump. The drunken one looks as if it was ready to keel over and put you into a world of pain.
You'll likely be worrying about the missing piece(s) - it will do no harm to drop the sump and check for debris either in there or in the oil pump strainer. For the sake of a gasket and a bit of extra effort, I would.
Aleather (09-04-2017)
#51
But your in there anyway.
