Quick Headrest Repair Questions...
Old Oct 16, 2014 | 04:37 PM
Poppyboy's Avatar
Default Quick Headrest Repair Questions...
I think I messed up. After I cut 12mm of the cable sheathing, there's a total of 21mm of drive cable visible (from the top of the sheathing where it was cut to the bottom of the drive cable. Does that sound right? If I put the remaining sheathing on with the metal grommet, there's still lots of drive cable exposed. What gives? Also, before putting everything back together, I tested the headrest motor with the seat switch, with the backrest back in position. It only stays on for a few seconds, then stops (both ways). Is that normal?
Old Oct 16, 2014 | 05:03 PM
Poppyboy's Avatar
Never mind. I re-measured, put everything back together, and miraculously, it all works fine now. Strange, but I'll take luck over skill any day!
Old Oct 16, 2014 | 11:18 PM
SeismicGuy's Avatar
Sounds to me like you did things right!
Doug
Shawn Svacha
Feb 6, 2022 04:53 PM
trosty
Dec 17, 2021 07:41 AM
SeanU
Sep 18, 2015 08:09 AM
timfountain
Sep 17, 2015 05:12 PM
jaggermang
Sep 8, 2015 07:07 PM
