quick inexpensive foggy lens fix
Old May 15, 2011 | 04:48 PM
hdsg's Avatar
Default quick inexpensive foggy lens fix
Good day:
Took pics but do not know how to post them. Took off the lens covers that snap in at the top of the headlight assembly. Lens cleared up but felt that not having the covers on could let dirt and rain in (Yes I do drive in the rain !!!) Bought 2 1/4" x 3/8 " threaded copper elbow fittings at Canadain Tire for 6 dollars each. Drilled a 1/2 inch hole in the center at the back of the cover. Screwed fitting in and used the nut that came with it to secure it on inside. Did not really need the nut as 1/2 inch hole allows for you to thread the fitting in nice and snug. It now is under the metal at the center back of the cover out of the way of the hood and water. Rotated so it was facing down in case any water does get in that area. If you want you could easily add a plastic tube to give an added measure of protection from water entry. So no water should get in, no taking apart of anything really and lamp assemble breathes. Less than an hour and 12 bucks
So I finally hopefully give something useful back to the forum and hope this helps someone !!
Howard
Old May 15, 2011 | 07:44 PM
brgjag's Avatar
I have just left my covers off, never have has any issues with stuff getting in. Been off for awhile. I think just another overkill thing on Jags part.
Old May 15, 2011 | 11:23 PM
xenophobe's Avatar
I took mine off the 97. That's the only way to keep it moisture free. My 05 has the covers on and never has condensation. (knocks on wood)
Shawn Svacha
Feb 6, 2022 04:53 PM
SCMike
Sep 22, 2015 07:34 PM
Rablaw1971
Sep 11, 2015 10:24 PM
kstevusa
Sep 7, 2015 01:12 PM
KarimPA
Sep 3, 2015 07:32 PM
