Quick pipe identification
Old Nov 25, 2018 | 03:10 PM
volkris's Avatar
Default Quick pipe identification
Hi, all
A few days ago I popped the hood on my '97 to check engine oil, and right on top of the V8 was an annoyed vole. He scampered away, but that might explain a few half eaten acorns I'd found near the throttle body.
It might also explain the smell of coolant I've been noticing lately.
While in there I noticed the condition of the tube in the second picture below. The foil shielding has been really compromised, and I was hoping someone could quickly confirm my suspicion that this is part of the coolant system, maybe leading to the heater core? I'm going to blame the little guy for chewing on the pipe, whether he's guilty or not.
It was hard to take a picture around the intake, but this is the area under the intake tube's elbow. I see two shiny pipes under there, one closer to the firewall that looks like part of the AC system, and this one that's right next to the engine.
In the first picture the tube in question can be seen just under the elbow.
Can anyone say off the top of their head what shiny flexible tube runs right next to the engine there?
Pipe peaking from under the intake
firewall to the left, and note other silver hose closer to firewall
Old Nov 25, 2018 | 04:06 PM
CorStevens's Avatar
do not know what it is but can tell you that under the foil is a plastic tube connecting to the base of the throttle body. the other end picks up an electrical connection in the compartment housing the ECU. any good automotive parts store can sell you a replacement for that insulation foil, just bring a sample and they can at least order it. it appears to protect the plastic tube from the heat of the exhaust system.
Old Nov 25, 2018 | 08:27 PM
Ltd's Avatar
Ltd
I believe it is a vacuum line, going into the fender well to the cruise control vacuum storage tanks. Pardon if my terminology isn’t correct.
Old Nov 26, 2018 | 05:52 AM
CorStevens's Avatar
if someone has a throttle body schematic or labeled photograph, we can probably identify the connection.
Old Nov 26, 2018 | 08:57 AM
Paul Pavlik's Avatar
I think that it is part of the EGR system. The foil shielding is to keep the heat inside of the tube.
Old Nov 26, 2018 | 09:18 AM
RJ237's Avatar
There should not be a egr pipe on a 97 NA US model. If it's there, could it be Canadian?
Old Nov 26, 2018 | 09:26 AM
motorcarman's Avatar
Jaguar DELETED the EGR on the 1997 MY XK8 (NAS cars) from VIN 011462-ON and issued a TSB for the new ECM part number.
XK8s from VIN 001036-011461 were fitted with EGR.
It is probably legal to remove the pipe/EGR valve if you can find a later ECM. Disabling the system will likely result in a DTC if the ECM is not replaced with one that is not looking for the EGR system.
Flash Programming is also a possibility if you have the capability.(see TSB 303-36)
bob
File Type: pdf
File Type: pdf
Old Nov 26, 2018 | 09:53 AM
volkris's Avatar
Ha! Ok, maybe not so quick a question.
Thanks for all of the suggestions. I'll have to take better pictures when the rain stops. @WhiteHat may have been on to something since it looked like the pipe goes from the throttle body to the compartment where I think the ECU lives. I thought the heater core was around there too, but maybe not.
I believe I saw a green connector sticking out from under the foil, so I'm going to try to snap a picture of that, if I saw right the first time.
ln69bt
46
May 26, 2018 01:39 PM
Northern XF
Jul 30, 2017 09:03 AM
Evan Trinh
Feb 25, 2016 06:04 AM
vincent661983
Jan 31, 2013 08:01 AM
plums
Jan 3, 2012 02:57 PM
