Radiator cooling fan relay location?
Old Feb 25, 2019 | 10:21 PM
Bshuford85's Avatar
Default Radiator cooling fan relay location?
1999 Jaguar XK8
Radiator cooling fan relay- i don’t know it proper location. Just got this car and the relay is currently
dangling next to the ground. Can anyone describe or show a picture of where it should normally be placed in the car? Whatever it was attached to must have broken.
relay
LJA 6702 AA
Old Feb 25, 2019 | 11:13 PM
DavidYau's Avatar
Default Radiator Fan Relay Location
Hi,
See PDF attached for the Jag XK8 1997 Range Electrical Guide. Page 20 of 123 shows the locations.
Good luck.
Old Feb 25, 2019 | 11:26 PM
DavidYau's Avatar
Default 1997 Range Electrical Guide
Sorry, too big to upload. See JPEG below.
Old Feb 25, 2019 | 11:58 PM
DavidYau's Avatar
Default Bonnet Pic behind LHS headlights
There seems to be a plastic open latch to screw a fixing on top of the retainer of the LJA6702AA relay. Maybe that's it.
Old Feb 26, 2019 | 12:39 AM
michaelh's Avatar
Adjacent to the LHS horn & foglamp:- look from underneath the car. Check this thread by dennisreda:
https://www.jaguarforums.com/forum/x...8/#post2014350
There should be a metal bracket attached to the module which is secured to the car with a single bolt:
Old Feb 26, 2019 | 09:16 AM
oldmots's Avatar
You could be referring to the cooling fan module which has multiple relays in it. The location for this is in a pocket in the center of the fan shroud. It is only pushed in there, so it could have fallen out. You can recognize it by the large gauge wires attached to it.
Bowmanconsult
Jan 8, 2024 02:23 AM
greenbeast16
Jan 13, 2018 10:11 AM
mrplow58
Jun 16, 2016 04:05 AM
armccoy
Oct 29, 2013 05:35 AM
swingarm
XJ40 ( XJ81 )
Apr 17, 2009 11:49 AM
