Radiator fans on all the time...
Old Mar 10, 2010 | 12:31 PM
rscultho's Avatar
Default Radiator fans on all the time...
Recently my radiator fans started coming on and staying on the entire time I am driving, and they continue for a few minutes after I stop. I know it is normal for the fans to stay on for a short while after turning the car off if the coolant is hot, but I've never experienced them staying on every minute I am driving.
Could this be caused from old coolant? I am going to change out my coolant since I haven't done that in a while.
Thanks in advance for any info
Old Mar 10, 2010 | 12:47 PM
avos's Avatar
It is a common problem for the thermosat to stick (in any position) for the 4.0 cars, chances are your thermostat is stuck more closed than open. If you still have your stock thermostat, better to swap it quickly, cheap and easy.
Old Mar 10, 2010 | 01:15 PM
rscultho's Avatar
Is there a better aftermarket thermostat to swap it out with?
Old Mar 13, 2010 | 02:18 PM
rscultho's Avatar
I got an OEM 185 degree thermostat and swapped out the old and replaced the coolant.
My fans are not coming on anymore - the old thermostat was the problem.
hoodun
Feb 20, 2023 05:52 AM
Mac Allan
Jul 20, 2020 05:46 PM
Seth
Nov 1, 2015 12:17 PM
LnrB
Oct 13, 2015 12:45 AM
3jagfamily
Oct 1, 2015 01:49 AM
