Radio works, but no sound!
Old Oct 9, 2011 | 10:50 PM
shanex25's Avatar
Default Radio works, but no sound!
Just bought a 1999 xk8 convertible tuesday. The radio head unit works great but there is no sound coming out of the speakers. I have thought that it is the amp malfunctioning in the trunk but how do i know for sure?
Old Oct 9, 2011 | 11:58 PM
Reverend Sam's Avatar
First, check to see if you have an amp. Only the cars with "premium audio" had amps. If you have one it will be above the CD changer, hidden behind the carpet covered cardboard-like liner. It's very flexible, just grab the top, pull it down, and see if there's an amp back there.
Old Oct 10, 2011 | 11:12 AM
shanex25's Avatar
Yes i have the premium sound and i have located the amp in the trunk. The wires running to the speakers out of the amp were all screwed up touching eachother going into the plug. I took it apart amnd fixed all the wires and checked all fuses. All fuses were still good and i have removed the amp. The only thing now is i need to figure out how to test the amp. If it was a normal after market amp i could test it easily, but this one just has to plugs instead of the regular "power, ground, remote, speaker +-" Any ideas how to test it? Also does anyone have a wire diagram of the plugs that plug into it so i can see if i have power? Thanks
Old Oct 10, 2011 | 01:10 PM
WhiteXKR's Avatar
I beleive '99 still had the Harmon Kardon Amp, in 2000 it changed to Alpine.
Shane, B+ is on the white 12 pin connector, pins 5 and 12 (brown/green wires). Ground is on the same connector, pins 4 and 11 (black wires).
I see no ignition switched power, so I suspect it is controlled by some on/off signal or datalink form the headunit.
You should consider downloading the JTIS CD (see the FAQ sticky at the top of this forum)...it has all the service info plus wiring diagrams.
Old Oct 10, 2011 | 08:56 PM
shanex25's Avatar
Thanks a million whitexkr!!! Thats exactly what i needed to know!
Old Jun 12, 2024 | 08:06 AM
Micael's Avatar
Default radio work's but not sound.
[QUOTE=shanex25;415236]Sì, ho l'audio premium e ho posizionato l'amplificatore nel bagagliaio. I fili che andavano agli altoparlanti fuori dall'amplificatore erano tutti incasinati, toccandosi l'un l'altro mentre entravano nella spina. L'ho smontato, ho riparato tutti i cavi e controllato tutti i fusibili. Tutti i fusibili erano ancora buoni e ho rimosso l'amplificatore. L'unica cosa ora è che devo capire come testare l'amplificatore. Se fosse un normale amplificatore after market potrei testarlo facilmente, ma questo deve solo essere collegato al posto del normale "alimentazione, terra, telecomando, altoparlante +-" Qualche idea su come testarlo? Qualcuno ha anche uno schema elettrico delle spine che si collegano in modo da poter vedere se c'è corrente? Grazie[/QUOTE
Old Jun 12, 2024 | 08:10 AM
Micael's Avatar
Hi Shane! i have the same problem..where are the fuse to check? thank's
philwarner
Oct 4, 2024 01:37 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
allenman85
May 10, 2021 03:11 PM
dcvickers
Sep 2, 2015 06:14 PM
XJsc-guy
Sep 2, 2015 11:43 AM
