Random warning Chimes
Old May 15, 2024 | 01:47 PM
Gerald Clark's Avatar
Default Random warning Chimes
I tried the method suggested with the nine steps outlined in the instructions multiple times. This didn't work on "Nigel" my 2005 XKR. In fact when there should be a chime, seat belt not fastened upon starting a drive, often there was no chime. I am at a loss. Can a repair shop just disconnect the chime? Any other ideas would be appreciated. (I've put up with this annoyance for many months but it is time for an elimination action.)
Thank you.
GLC
Old May 15, 2024 | 09:24 PM
giandanielxk8's Avatar
Thank you.
GLC
These cars never had a warning chime for an unfastened seatbelt. They were made back when the decision of whether if you live or die, whether if you remain in the car or are shot out of it through the windshield in the event of a crash, was up to you to decide.
The warning chimes ther cars DO have are:
  1. Door ajar with the key in position II.
  2. Right when the car is started.
  3. When the turn signals and/or hazard lights are activated.
  4. When the car is turned off with the gear lever not in Park position.
  5. When setting off with the Park brake (or e-brake) engaged.
Is any of those not activating when it should? Are you getting a warning chime or gong besides those?
Old May 16, 2024 | 01:50 PM
Old May 16, 2024 | 03:17 PM
Y2KJag's Avatar
My 2000 also chimes when the ignition is off, key in, and door opened.
Old May 16, 2024 | 07:04 PM
Yes that would be the Door Ajar one I mentioned. I wasn't sure if it was key in on its own or key in II position.
Old May 17, 2024 | 01:05 AM
Y2KJag's Avatar
Both.
hdjag
Aug 15, 2024 05:08 AM
Gerald Clark
May 16, 2024 08:03 PM
280zx-turbo
May 27, 2016 02:21 PM
SeismicGuy
Jul 26, 2015 10:32 AM
Cream
Jan 26, 2012 02:32 PM
