Rationale of X-100 brake bleeding sequence ?
Old Jan 10, 2025 | 05:12 PM
zray's Avatar
Default Rationale of X-100 brake bleeding sequence ?
Most cars I’ve worked on had a factory recommendation of bleeding brakes starting with the wheel most distant from the master cylinder.
in contrast, my x-100 shop manual stipulates starting with the left hand front caliper and working towards the rear right caliper lastly.
what is the rationale for doing the bleeding procedure this way ?
I’m sure its covered in the forum, but I haven’t discovered it yet ?
Z
Old Jan 11, 2025 | 01:26 AM
Throwback's Avatar
how odd! I haven't got round to doing my brake fluid yet so hadn't noticed that. But, I have done brake fluid on my miata and they start on the driver side rear because if you actually look at the brake hose routing, the driver side feeds off a union right by the passenger side and is therefore furthest away. So try following the brake hose line routing and that may give you your answer.
Old Jan 11, 2025 | 03:34 AM
dibbit's Avatar
Given that each wheel has its own brake line back to the master cylinder, I don't suppose it matters that much, but maybe Jaguar knows the internal layout of the master cylinder and took that into account?
In the old days, a split system had two lines going to two wheels each and I can see why you would want to bleed the longest line of the pair first.
Having said all that when I changed the brake fluid on my XKR I started with the longest line and the brakes seem to work just fine. IIRC the Brembo caliper has two bleed nipples on opposite sides of the caliper - easy to miss the inside one if you don't realise it is there.
Old Jan 11, 2025 | 06:33 AM
Jon89's Avatar
When Wayne and I bled the brakes in my wife's 2006 XK8 a couple of years ago, we started with the longest line and worked our way in. The braking system continues to work exactly as designed....
J_C_R
Aug 15, 2022 06:40 AM
tellis41129
Apr 27, 2021 11:43 PM
BSM
Jun 10, 2017 03:15 PM
wardf
31
Jan 23, 2017 10:06 AM
Grant84
May 5, 2014 10:00 PM
