Rattle lower end of engine on deacceleration
Old Jan 10, 2025 | 07:30 PM
jagcoupes's Avatar
Default Rattle lower end of engine on deacceleration
Is my aj27 4 litre terminal? Drives fine
click on the link to hear the noise
https://youtu.be/7WBln7731DQ
Old Jan 11, 2025 | 02:23 AM
Pistnbroke's Avatar
KISS sounds too light for the big ends ,they would not all fail together usually just one ...wip off the top covers and check the timing chain...its there all the time not just on deceleration. Maybe just the top guides have failed. You will find bits of the guides in the sump if the guides have failed
Old Jan 11, 2025 | 05:41 AM
michaelh's Avatar
^^+1
Definitely too light for bottom end, IMO. Could well be rattly chains, but I'd whip the serpentine off and run the engine briefly for a $0 check if it's something in the accessory train.
Keep the tests to an absolute minimum until you've eliminated any problem with the chains/tensioners.
I'd also recommend that you use a spreader of some sort between the jack cup and the front crossmember.
Old Jan 11, 2025 | 10:14 AM
RichardS's Avatar
Does it make the noise when the engine is in gear and driving the wheels?
Remove accessory belt and quickly try again as suggested.
Remove oil filler cap and listen there.
Does it sound as loud when listening from above the engine?
As already stated, it does not sound like mains bearing, big ends or small ends.
Richard
Old Jan 11, 2025 | 10:19 AM
Pistnbroke's Avatar
Engineers stethoscope on timing chain cover may help.
Old Jan 13, 2025 | 05:08 AM
markmywords's Avatar
Loose front crank pully?
Old Jan 16, 2025 | 06:34 PM
jagcoupes's Avatar
Thank you everybody your assistance in this matter. Due to time restraints I have sent the car to my mechanic to take to covers for further investigation. It does sound like chains even though both primary and secondary were replaced 90k ago by Graeme Lord.
I removed the serpentine belt but all is ok there.I
will keep you posted with a further update
Rodkel
Oct 14, 2023 10:23 AM
Supercharged81
Aug 19, 2019 06:10 AM
Quartzboy
Mar 20, 2018 10:44 AM
ukdude
Mar 7, 2015 07:38 AM
