Re-installing the Camshaft
Old May 17, 2012 | 06:40 AM
JagYour's Avatar
Default Re-installing the Camshaft
I just installed the new metal secondary tensioner on the right bank. Now I am trying to bolt the camshaft back down. It does not seem to want to go back down. The second last cam lobes are bringing up against the tappet buckets. Do I just go through the ritual of methodically re-installing the cam caps and it will eventually draw the camshaft down?
Old May 17, 2012 | 06:45 AM
WhiteXKR's Avatar
It will draw down. Tighten them evenly just a bit at a time.
To avoid this problem when you do the other side, it is best to rotate the engine before removing the cam (from the bolt on the crankshaft harmonic balancer) so there is minimum pressure on each of the tappet buckets.
aholbro1
Dec 29, 2024 06:46 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Markus
Sep 28, 2015 01:55 PM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
