Re-Installment Anxiety!
Old Aug 21, 2012 | 03:40 PM
mick99's Avatar
Default Re-Installment Anxiety!
Waiting for my rebuilt Throttle Body. Can I anticipate any peticular problems after I re-install it? Must I re-calibrate anything? ( I sent in the T B that was already in the car ) Does that make it a Plug In and Go? .....Thanks for any comments!....mick
Old Aug 22, 2012 | 08:01 AM
steveinfrance's Avatar
Worth doing this
setting WOT,covered in JTP939
Re-programming is done with the ignition switch in position II a follows:
Slowly press the accelerator pedal fully through the kickdown detent to the floor. Hold 5 seconds
Release the pedal and repeat the action.
Old Aug 22, 2012 | 11:45 AM
mick99's Avatar
Wow, that sounds easy enough! Thanks steveinfrance!!!
Old Aug 22, 2012 | 01:05 PM
hdsg's Avatar
i know when i disconnected mine to clean connectors when i started the car is was surging ( Pulsing ) not to high on the revs but up and down and i thought great what the *&(*(*& do I do now. But taking the positive off battery and touching ground on negative terminal ( explained in the forum ) to drain electronics fixed it. It was magic !!!! (haha)
Howard
Old Aug 23, 2012 | 04:32 AM
Mick,
The full procedure is in our download area here
Free Cloud Storage - MediaFire
Go into Tech Guides and you'll see a file called Replacing Throttle Body
aholbro1
Dec 29, 2024 06:46 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Markus
Sep 28, 2015 01:55 PM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
chatmanx
Sep 11, 2015 07:17 PM
