Rear Brake Light Failure (or not)
Old Jan 16, 2022 | 07:55 PM
HongKongMike's Avatar
Exclamation Rear Brake Light Failure (or not)
Hi, I'm a new member so sorry if this is old news but I have a problem with my nearside brake bulb.
I have replaced the bulb as a failure error was showing. The bulb is working as a taillight but when the brake is depressed it does not 'brighten' and it still shows a failure error !!!
Any ideas as to what the problem is before I have to take it to the Jaguar garage ... I live in Hong Kong and believe me a Jaguar garage here is ridiculously expensive.
Many thanks
Old Jan 16, 2022 | 09:41 PM
ozbot's Avatar
What year is your car? I had a similar issue with the brake lights on my '97 XK8. I replaced the ground wire to the circuit board with a heavier gauge wire and now they work fine. Lots of threads here on this issue but I don't know in which years this was a problem.
Old Jan 16, 2022 | 10:46 PM
Johnken's Avatar
Mike, I thought the same thing as Oz
They made the car with a rear lights ground wire that is too thin. Pull the light pod, find the black ground wire sometimes its a dead giveaway- the wire has obviously started to melt anyone can see it.
How did I fix mine? Soldered a 18guage wire to a ring connector, riveted the ring to the metal ground plane on the board that holds the lights, crimp/soldered a larger ring connector to other end of the wire. Picked a nut protruding back into the trunk in that area, ensured bare metal showed under the nut, put the ring connector on, tightened nut - job finished.
If you don't have a rivet gun you could use a nut and bolt. Just tightened it real good - lots of bumps in its future.
John
Old Jan 17, 2022 | 01:44 AM
Hi its a 2007/2008 model
Mike
Old Jan 17, 2022 | 01:53 AM
Hi John, many thanks for your rapid reply (and to Oz as well) and the detail of the solution...
So that I understand things, it seems the solution can be done simply by removing the light cluster (which I had to do to change the bulb) and attaching a ground from the light cluster to a bare metal point on the body? Sorry to sound so basic but this is all new to me but I do understand the principle of grounding/earthing.
Mike
Old Jan 17, 2022 | 02:06 AM
ozbot's Avatar
Yes. I did the same as John described above but I drilled a small hole in the metal plate and used a nut and bolt with a star washer on each side. There's a few nuts near the light panel you can use for the other end. It's a 15 minute job with less than $10 in parts. Mine has held for 3 years now with no problems.
Old Jan 17, 2022 | 11:00 AM
bcprice36's Avatar
HKMike,
You are in the 1996-2006 XK8-XKR File...You need to be in the XK8-XKR 2007 on File.....Some of us, Myself included have never been in an Aluminum Jaguar......Hope you find the answer to your question over there!
Billy Clyde @ Cinco Ranch
NorCalDiesel
Sep 14, 2023 02:52 PM
MrAndersonGCC
Nov 5, 2021 10:35 AM
Johnnywrench
Apr 24, 2018 10:14 AM
Burnham
Aug 27, 2016 03:29 AM
Kikevzqz
Jun 15, 2014 03:34 PM
