Rear Brake Pad Replacement/Recalibration
Old Feb 16, 2018 | 08:28 PM
jaguar51's Avatar
Question Rear Brake Pad Replacement/Recalibration
I may switch out the semi metallic rear brake pads for ceramic on a 2002 XK8 and was wondering if after the rear brake calipers were opened up and the new pads are in does the parking brake have to be recalibrated such as on the 2003 S type? The S type must go thru a recalibration procedure but does the XK8 also or not?
Old Feb 16, 2018 | 09:21 PM
rothwell's Avatar
The S-Types have the electronic parking brake. XK8 has the old school lever and cable style so you should not have any re-calibration needed other than "pull lever and verify it works".
Plus the parking brake shoes are separate from the caliper, instead being on the inside of the rear rotor like a drum brake. If you are not replacing the rotor you won't affect the parking brake at all.
If you are replacing the rotors you should buy new parking brake shoes too.
Old Feb 16, 2018 | 10:03 PM
jaguar51's Avatar
Red face Rear Brakes
Thank for your reply. The parking brake shoes and rotors/pads were replaced 3700 miles ago, I want to switch out the semi-metallic pads for ceramic and have less break dust along with it not sticking the rims as the semi-metallic dust does.
Cheers,
ER
Old Feb 17, 2018 | 03:01 AM
Seeing a diagram first often helps before you crawl under the vehicle.
Rear Brake Pad Replacement/Recalibration-parking-1.jpg
Rear Brake Pad Replacement/Recalibration-parking-2.jpg
If you are only changing rear brake pads, you won't disturb the parking brake assembly or its adjustment.
michaelodonnell123
Feb 17, 2016 10:47 PM
amgeater
Apr 24, 2014 12:37 PM
nebelfuerst
Apr 14, 2014 10:09 AM
Ahmed Khalifa
Mar 2, 2010 05:14 PM
