Rear Diff
Old Mar 17, 2015 | 12:49 PM
jetjack's Avatar
Default Rear Diff
Was checking all my fluids before a 1200 road trip and cannot figure out how to check the rear differential level?
Any help?
Thanks in advance!
Jack
Old Mar 17, 2015 | 12:57 PM
daxter1987's Avatar
Of the top of my head your differential has a fill plug. You need to put a half inch drive extension and ratchet, crack it and fill it until the level is at the bottom of that fill plug. Is a bit of a pain to get to but you can access it from the rear of the diff look around the brace.
Old Mar 17, 2015 | 02:36 PM
jetjack's Avatar
Thank You daxter, I can see the plug (barely) but looks impossible to loosen with all that bracketing in the way
Old Mar 17, 2015 | 07:02 PM
RaceDiagnostics's Avatar
It is just possible.
See here https://www.jaguarforums.com/forum/x...iff-oil-71492/
Old Mar 18, 2015 | 03:36 AM
Commendable attention to detail but if there's no sign of leakage from the input/output seals or around the drain plug or casing joint, I wouldn't go looking for trouble.
Old Mar 18, 2015 | 09:02 AM
jetjack's Avatar
It looks like the input shaft seal may have a leak, that's why I was checking, just need to get it from FL to home in Ct to sort things out, leaving in an hour
Old Mar 18, 2015 | 10:36 AM
K.Westra's Avatar
If you are curious, Welsh Enterprises sells the pinion seal separately while Jaguar requires you to buy the entire bearing. I only found this out after I did the whole thing.
FrickenJag
Jun 16, 2025 02:15 PM
H20boy
Dec 24, 2024 03:23 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
AtholC
Sep 9, 2015 09:07 PM
1100me
Sep 7, 2015 06:26 AM
