Rear End Gear Change and Pois Unit Instal with Drain Plug
Old Oct 14, 2013 | 07:21 PM
aode06's Avatar
Default Sticky Rear End Gear Change + Posi Unit Instal+ Drain Plug
I caught this writeup and bookmarked it, its not in our stickies
Jaguar Quaife Differential Install – Jacks Transmissions LLC
You send these guys your rear end, you get the gears of your choice, new bearings,new posi, new drain plug, seals etc.
Don't know the cost for the options.
My question is, will a gear change change the speedometer, or miscalculate the traction control/abs unit in any way?
Id love to have some 3:55's or 3:73;s in the city.
Old Oct 15, 2013 | 08:13 AM
aode06's Avatar
Just found out its safe to upgrade the gears and also make the unit a posi from my local dealership
A good set of gears is in great need for the 4.0 DOHC, it will wake the whole car up.
This is definitely on my list of performance modifications, to go along with a cold air intake and performance exhaust.
Ive driven cars with gear swaps from 3.08, 2:73 changed to 3:73 and what a difference it makes!!!!, now with posi, you can conquer all that beloved thrust.
Old Oct 16, 2013 | 09:49 AM
aode06's Avatar
To the guy that emailed me, no this is not that difficult of a job, as other cars to just remove unit and ship out.Its on my to do list.
BrentGardner
29
Dec 16, 2024 12:13 AM
DavidNagel
Dec 29, 2017 09:16 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
23t.chris
Sep 2, 2015 08:09 AM
Spikepaga
Aug 30, 2015 12:59 PM
