Rear parking aid sensor fault
Old Dec 25, 2018 | 06:48 PM
zray's Avatar
Default Rear parking aid sensor fault
after doing the prerequisite forum searches on this topic I have narrowed down the failure of this system to one of the inboard sensors. It figures the-easy-to-get-to outboard sensors are just fine. But the driver side inboard sensor is silent. Maybe it's a wiring issue, or poor connector at the sensor, or the sensor itself.
Some posts mention that "small hands" are needed. But all the access I see for the two inboard sensors are a wiring hole for each one about the size of a half-dollar. No room for fingers in there to turn and release the bayonet fitting holding the sensor in place.
My question is, on a 2002 XKR coupe, does the bumper have come off to access the sensor. ?? From the posts I've read, some cars seems to have access holes, and some don't. I don't see any holes that are large enough fort any access.
It looks like only the plastic part of the bumper needs to come off. Will it come off without taking off anything else ?
Z
Old Dec 26, 2018 | 07:48 PM
mhminnich's Avatar
Try giving the offending sensor a sharp rap with a screwdriver handle our similar. It brought one on my son's car back to life.
Old Dec 28, 2018 | 04:27 AM
Originally Posted by zray
.....It looks like only the plastic part of the bumper needs to come off. Will it come off without taking off anything else?
YES. There's four fixing bolts and then it slides off rearwards. Useful to have an assistant as it's suprisingly floppy
This is my 2001 XK8. The mountings on US specification vehicles are different from European. Ours are just a plastic bracket but US ones have an energy absorbing strut as shown in the drawing.
Old Dec 28, 2018 | 04:48 AM
frankc's Avatar
I have always managed to get to my sensors by reaching up underneath. Usually find its a loose wire etc. As suggested before a good tap usually fixes it too. If your not sure which sensor is faulty you can listen to them and they give off a faint tapping/clicking sound if they are working.
Old Dec 28, 2018 | 08:40 AM
zray's Avatar
".......The mountings on US specification vehicles are different from European. Ours are just a plastic bracket but US ones have an energy absorbing strut as shown in the drawing.
thank you for the illustration. As soon as my unheated garage warms up a little I'll tackle the bumper removal.
I've a pretty good idea it's only the left inner sensor. All the other ones sing out when the can is in reverse. I'm hoping a good cleaning of the sensor connection to it's wiring harness will do the trick
I have a fair understanding how the sensor is removed from the bumper, similar to old type taillight bulb. Just push in against the spring and rotate. But I don't know the wiring comes off of the sensor . Just looking at the end sensors, I don't see a bale that has to swing up, or anything similar etc.
Can anyone describe how the wiring connector is freed from the sensor ? So far I haven't broken any of my cars's connectors, but that possibility is my #1 concern whenever I work on it.
I'm experienced on what we now consider to be "vintage" cars and vintage motorcycles. But a novice at modern engineering fasteners. I think a sticky that illustrated the proper way to remove ALL the cars wiring connectors and hose connectors would be a great addition to the forum for the other Rip Van Winkle's like me.
Z.
PS FrankC, I can reach the2 outboard sensors easily enough, but the 2 middle sensors do not have any access other than the hole the wiring goes thru, well under two inches in diameter more or less. Too small to get more than a finger inside of it.
Old Dec 28, 2018 | 02:15 PM
frankc's Avatar
Here you go. For the main bit skip to 2:26 ish.
Old Jan 5, 2019 | 05:19 AM
zray's Avatar
finally had a day above freezing and took the bumper loose far enough to use a pair of needle-nose pliers to turn and remove the non-operational sensor. Still don't see how a persons hands could access the middle sensors without enlarging (butchering) the access hole.
Cleaning it and the wiring connection did not result in a resurrection. Switching it out for one of the good sensors confirmed the fault follows the sensor when it is plugged in in a different spot.
Z
sofalvi
Dec 13, 2018 02:59 PM
Jesse Chen
Oct 24, 2016 03:01 PM
uclabrruin1989
Jan 3, 2013 08:27 PM
s type
Sep 9, 2008 09:42 AM
