Rear Shock replacement
Old Aug 19, 2022 | 01:18 PM
  #41
JayJagJay's Avatar
One of my XKRs originally had CATS and the dampers were replaced with standard black Bilstein units before my ownership.
The CATS module was disconnected and no fault is displayed in the INSTPK.(it just rides like a normal XK8)
The other XKR has everything in tact with original CATS still working fine.
Much the same story.
So, apologies for my earlier post. I think I am wrong about the CATS shock, stating that it defaults soft, light or normal. But my experience is bout the same as Bobs
I got a new set of nonCatt Blistens for the 04 XKR (the shocks were not bad) and replaced the shocks when I swapped the DEAD 04 XKR upper shock mounts. I didn't car about the CATs feature. Unplugged the system. Rides NICE!
Clearly I car more for the XKR...
I took the old CATs shocks from the XKR and put them on the XK8 which still had the OE green shocks. 215k on them. SURPRISED to find they were not bad either. But still. Replaced them with the old (unplugged) CATs shock from the XKR... Much much improved on the XK8. Good good.
No dental work or chiropractic care needed.
Jus say'n
Old Aug 20, 2022 | 07:08 AM
  #42
JamBar's Avatar
Thumbs up
Jus say'n
Well, you and Bob both have shared some valuable experiences there. I must admit I am tempted to get new standard shocks Bilsteins would be good). The problem is I would need 4 (front and rear) and that would double the cost, but probably still cheaper than 2 new CATS dampers, so in reality not a problem.
I will have a think over the weekend but thank you both for your info. Thumbs up
Old Aug 28, 2022 | 05:01 AM
  #43
JamBar's Avatar
Quick update.
The update is there is no update yet, partly working on other cars and partly waiting for new bushes to be fitted.
Old Aug 10, 2023 | 09:36 AM
  #44
JamBar's Avatar
Quick question.
I have to do the same on our XJ8 (X308).
Is it the same process? Looks like it is, pretty much the same rear config.
Old Aug 10, 2023 | 01:57 PM
  #45
motorcarman's Avatar
The rear suspension is nearly identical between the X100 and X308. Rear stabilizer bar not fitted to all X308.
Old Aug 10, 2023 | 04:24 PM
  #46
JamBar's Avatar
Thanks for the reply.
Great, that is what I thought.
Here we go again then.......
Old Aug 14, 2023 | 10:31 AM
  #47
JamBar's Avatar
The X308 ones come out with far less pain.
guncharmer
Sep 9, 2024 09:44 AM
pan84
Feb 13, 2023 08:33 AM
Mr rx-7 tt
Dec 13, 2021 05:05 PM
Amphicar770
Jul 12, 2017 10:38 PM
