Rear Speakers dead
Old Aug 22, 2009 | 08:49 PM
jkrubinlaw's Avatar
Default Rear Speakers dead
Driving home (from the shop) the rear speakers suddenly cut out completely. Both sides are out in back. Are there any fuses or connections that I should check first? Thanks in advance for the help.
Old Aug 24, 2009 | 10:01 PM
daddyo007's Avatar
Did you check all of the obvious stuff. Like it doesn't work with the radio? cd player, tape deck? Are they all with out sound in the rear? Did you try to change the fader from front to rear to see if it just goes quite. In my coupe I believe I just have the one rear speaker on the deck. Everything else is up front. Did you have anything in the trunk that might have caught a speaker wire and pull it off or broken connection? All of the speakers are accessable you could pull each and test them out side the car on another system to see if the speakers still function. Just some obvious stuff to look for. Not really an answer but cheap way to eliminate what you don't know.
Old Aug 25, 2009 | 09:58 PM
jkrubinlaw's Avatar
Being mechanically incompetent, but very good at following direction this will be a big help this weekend. Thanks.
Old Aug 26, 2009 | 11:00 AM
H20boy's Avatar
Do some investigative diagnosis and please follow up.
Old Aug 27, 2009 | 08:53 PM
Robscountach's Avatar
I didn't there were any full-range speakers back there. They're all in the door and dash.
I know the Convertible has subs that sit by the seats (2) and the Coupe's are in the back (1).
Old Aug 28, 2009 | 10:39 AM
jkrubinlaw's Avatar
It's the subs that stopped working all of a sudden.
Old Aug 28, 2009 | 10:46 AM
H20boy's Avatar
Well, the amp has its own sub 'channel', so it could be just the amp went bad.
kevinl
Oct 31, 2019 06:15 PM
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
jdzubas
Oct 4, 2015 09:14 AM
Dz1rfj
Sep 16, 2015 03:44 PM
