Rear suspension electrical switch
Old Dec 23, 2020 | 06:38 AM
Bob Boyle's Avatar
Default Rear suspension electrical switch
Along with a good Mechanic and friend, I replaced all the rubber components on the front and rear suspension on my 63k 2003 XK8. When we were working on the removal of the drivers side rear damper and spring assembly we came across a switch that we had to disconnect to open things up. The actuator of this switch was connected to the wishbone and the body of the car; it looks like a potentiometer. Does anyone have any idea what it's for; I am of the opinion that its either for the stability control or abs systems or both?
I look forward to hear from someone on this.
Old Dec 23, 2020 | 07:52 AM
fmertz's Avatar
I initially thought so as well, but I believe it is used as input for auto-leveling the headlights.
Old Dec 23, 2020 | 08:46 AM
Bob Boyle's Avatar
That makes.much more sense.
Old Dec 23, 2020 | 09:17 AM
astromorg's Avatar
You'll see there's also another sensor on the front suspension, also part of the headlight levelling system.
In many countries the levelling system is a legal requirement if HID headlights are fitted.
Old Dec 23, 2020 | 09:22 AM
ccfulton's Avatar
Sensors for the headlight leveling look like below:
1 is front, 2 is rear.
Old Dec 23, 2020 | 09:37 AM
Bob Boyle's Avatar
This is good information. Thanks for sharing your knowledge.
Doug
Nov 7, 2018 08:39 AM
stuart goodwin
Sep 28, 2016 11:14 AM
Ferdie
Australia - Queensland
Jul 28, 2015 03:55 PM
eric7216
Mar 20, 2012 02:31 PM
lorand
Mar 18, 2009 08:56 PM
