Rear wheel bearing inner vs outer seal
Old Oct 28, 2020 | 09:15 PM
Johnken's Avatar
Default Rear wheel bearing inner vs outer seal
Guys this one always kicks my butt. Let me bounce it off you, make sure I'm heading down the easiest path.
There are 2 rear bearing seals inner and outer for each wheel. They are nearly identical but seal 1 has a larger diameter than the other.
I admit I get confused and neither is in its factory package any longer. You'd think it'd be obvious by just looking. Its not. The smaller seal could fit on either side! The larger one will require some motivation, but I want to be sure I'm fitting into the correct side.
I can't figure where the larger one should go. If I put it in the outer position (side nearest the car next to you), the hub doesn't seem to fully insert. If I put it in the inner position (side facing the diffetential) its larger than the hole in the carrier, I wonder if it can be forced in to it.
Maybe one of you guys remembers this, I hope its an obvious answer. Thank you!
John
Old Oct 29, 2020 | 03:35 PM
michaelh's Avatar
Jon,
Would measuring the ID & OD of each seal help to determine which is which?
FWIW (probably not much), the IDs look different on JEPC.
Johnken
May 21, 2020 10:25 AM
Scotlad
Nov 18, 2018 11:52 AM
NebRuss
XJ40 ( XJ81 )
Sep 27, 2016 07:48 PM
hdfx81
Apr 10, 2014 08:43 AM
FastKat
Sep 29, 2012 09:06 PM
