Rear Window brakelight
Old Jun 1, 2012 | 04:00 PM
AB22 Easy Tiger's Avatar
Default Rear Window brakelight
The brake light on the rear window of my 01 Coupe has come off and I can't for the life of me see how it clips back on.
Any bright ideas?
I'll take a couple of photos of the clips and "mounts" when it cools down a bitt his evening.
Anyone else had this?
Old Jun 1, 2012 | 04:16 PM
ccfulton's Avatar
There should be two metal clips on the glass that snap into a matching pair on either side of the light assembly. The light assembly has some plastic tabs that snap into the interior colored cover.
So the glass holds the light that holds the cover in place.
The plastic bits of mine broke all to pieces so I ended up putting the light back into the housing with some double sided tape and then snapping it into the clips on the glass.
It's not as tight as original but seems to get the job done.
To install it, all you need to do is slide is down the glass until it pops past the metal clips on the glass. Removal is the reverse, just pull up. Plugging it in is sort of a pain as the wire harness is fairly short.
Old Jun 1, 2012 | 04:41 PM
Thanks, the metal clips on the window appear to be missing. Looks like double sided tape.
Old Jun 1, 2012 | 06:34 PM
plums's Avatar
The clips might now be on the light itself if it peeled away.
The clips *probably* mount to the glass using the same glue as used for mirror mounts.
Old Jun 1, 2012 | 11:53 PM
Actually, that's probably a good call.
Whatever the answer I guess I need some glue or Double sided tape
Old Jun 2, 2012 | 10:39 PM
Fedoraja1's Avatar
Mine broke too; hit a pot hole and rattle, rattle, rattle. Off it came, garbage it went.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
