rear window replacement picture needed
Old Aug 16, 2012 | 06:45 PM
spf72's Avatar
Default rear window replacement picture needed
I have received my new rear window regulator and am putting it back in the vehicle. I made the classic mistake of not taking pictures when I took it apart a few days ago and I am now hung up on what seems a minor point.
The instructions call for me to install the 2 bolts that hold the window to the regulator. The issue is that there are 4 nuts welded to the regulator frame that match up to the window bracket. The top two clearly are for the bolts I have but it looks like the bottom two should have the adjustment bolts and nuts although when you put them in there would be no way to adjust the window with these bolts once the window is in.
I was wondering if anyone has a blow-up picture or diagram of how the window is meant to bilt back to the regulator?
Steve
Stoney85
Jun 10, 2021 09:14 PM
Stoney85
Australia - Queensland
Jun 7, 2021 11:49 PM
Goncalo Proenca
Aug 29, 2015 06:22 AM
dpappyp
Aug 27, 2015 06:31 AM
divingmom
Aug 25, 2015 07:54 PM
