Rear windows opening when operating front windows
Old Apr 1, 2025 | 06:24 AM
2003RagJag's Avatar
Default Rear windows opening when operating front windows
I have a problem with my 2003 XK8 Convertible, yesterday since the two months of ownership the rear windows are going down anytime you work the front windows. To bring them back up I have to start a top down procedure and stop it half way to be able to raise windows up after top locks down. Now I have to drive with the front windows closed if I want to keep the rear windows up. These two systems are supposed to be completely separate so I don't know why this is happening.
Any help would be appreciated.
Old Apr 1, 2025 | 09:36 PM
cjd777's Avatar
Oz, I waited all day to see if anyone else has had this problem, guess not.
Time to try a reset with a battery disconnect.
Put everything in place and take the negative off and positive off, hold together for 30 seconds and reattach.
See what happens.
Wayne
Old Apr 7, 2025 | 10:45 AM
Theo14's Avatar
I had/have the same issue. Never tried the full reset, but ended up adding a switch as explained in below video because I wanted to be able to raise the rear windows with the top down to reduce air flow in cabin with top down. Switch works great, but didn't make as much of a difference wrt air flow as I hoped. However I can raise the rear windows anytime without having to open/close the top.
Old Apr 7, 2025 | 12:14 PM
2003RagJag's Avatar
https://www.youtube.com/watch?v=VRGRFXv7PoA
Thanks Theo, I had this problem two days in a row but it went away. Still drove me crazy 😧. I'll check out this video as a backup in case it happens again.
Oz
M1redskin
Sep 30, 2022 05:04 PM
malc4d
Oct 3, 2013 09:53 PM
motomental
Aug 16, 2013 06:55 PM
MDJag
Feb 20, 2011 08:49 PM
