Rehash : P0171 & P0174
Old Jul 29, 2025 | 10:28 AM
rhhall1's Avatar
Default Rehash : P0171 & P0174
1997 XK8: I know I may be rehashing old threads. When the engine is at operating temperature (190 degrees F), codes P0171 and P0174 accompany a short-term rough idle when the car is at a stop following normal cruise. Occasionally, the CEL will illuminate, but not always. When increasing engine speed, the car runs normally. I have looked for vacuum leaks and haven’t found any obvious ones. I have replaced the MAF with an off brand one from Amazon. I have not had a smoke test performed. Thoughts?
Old Jul 29, 2025 | 11:11 AM
bladerunner919's Avatar
Well, start with the smoke test!
Old Jul 29, 2025 | 12:16 PM
JagV8's Avatar
To check, watch fuel trims at idle (warmed up engine) - likely they will be quite big (>10, say). Rev to 2500 or so and if they drop you for sure have a leak.
Old Jul 29, 2025 | 12:20 PM
Jon89's Avatar
Go back to the correct and genuine Denso MAF sensor.
Check the accordion section of the black plastic intake pipe for splits and cracks, particularly its underside (which bakes in the heat of the engine bay and gets extremely fragile).
Check the two VVT solenoid O-ring seals to see if they are weeping oil. If they are, they can also be losing air there.
sdbill
Nov 27, 2022 08:56 AM
Clapton7
Jul 12, 2020 03:45 AM
Chuck Schexnayder
Dec 21, 2016 11:10 AM
jazzwineman
Sep 26, 2016 01:23 AM
LoyalXTyper
Oct 26, 2012 06:28 PM
