remote fob
Old Nov 26, 2012 | 12:23 PM
dennisw's Avatar
Unhappy remote fob
remote fob only works when it feels like it.tested batt 3volts.replaced brand new one just in case.then i notice when taking key out of ignition the little flap only closed now and then..put a bit of 3in1 on key and in the lock/ig barrel..seems ok now ..is this comon and how to perminantly cure it?
dennis
Old Nov 27, 2012 | 09:03 AM
dennisw's Avatar
mmm
Old Nov 27, 2012 | 09:22 AM
oyster's Avatar
Hi.
As you probably know the car will not lock if the flap in the ignition barrel does not slide into place when you remove the key. This is a common problem over age. Try to clean it carefully, and then lubricate sparsely with a non sticking oil. WD40 tends to get sticky over time. Be careful not to get anything stuck in the key hole or flap mechanism.
Old Nov 27, 2012 | 11:18 AM
Jon89's Avatar
Graphite powder sold exclusively to lubricate locks may be your best bet. Use it very sparingly - a little goes a long way....
Old Nov 27, 2012 | 12:16 PM
per segelberg's Avatar
Have the same problem, will try with graphite powder. Thanx for the tip.
philwarner
28
Jul 11, 2017 10:21 AM
redxk8
Sep 30, 2015 08:18 AM
Listers
Sep 30, 2015 07:45 AM
zdrapec
Sep 25, 2015 05:49 AM
