Replace two-month old valve cover gasket?
Old Sep 19, 2011 | 01:15 PM
The Coupe's Avatar
Default Replace two-month old valve cover gasket?
Hello guys-
Quick question here:
New valve cover gaskets (including spark plug o-rings) were installed in my car about 2 months ago. I would now like to pop one of the valve covers off to investigate a couple of things.
Since my current gasket is only two months old, must I replace it when I pop the cover off this time, or can I use the current gasket and o-rings if they appear to be in good shape?
I know the rule of thumb is to replace, but maybe since the gasket is just two months old, I can get away with it. I'm assuming I should reapply gasket sealant when I bolt everything back together...which sealant is recommended?
Thanks very much for your help.
Old Sep 19, 2011 | 01:20 PM
XKRacer's Avatar
Dont use sealant there is no need and you will just make it worse, if the gasket is only 2 months old as you say it should be fine, it is only when they are old and the rubber has gone a bit hard does it ever cause probs, they are made from quite a soft rubber and I have never had any worries.
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
laserguy
Sep 3, 2015 02:02 PM
XFR_Gold
Sep 2, 2015 12:24 PM
