Replacement head unit, need a security code?
Old May 25, 2018 | 01:01 PM
Ophitoxaemia's Avatar
Default Replacement head unit, need a security code?
Replacing the radio head unit, can I just buy one off eBay, and do I need some security code with it or just the hardware?
2000 XK8 Coupe, premium sound.
Old May 25, 2018 | 01:16 PM
European radios were coded in that era and a four digit code is required to unlock them after a battery disconnect.
A very small number of US owners (only 4 that I can recall on this forum) have reported having coded radios fitted to their XK8/XKR's. It is very rare and unlucky to require a radio security code in a US specification vehicle.
Old May 26, 2018 | 07:19 AM
cjd777's Avatar
Graham, my 2000 XK8 has the original cards and paper work that came with the new cars that have the radio code on them. Don't know why two cards, size of a credit card. So go figure on that.
Now over the years, doing work and disconnecting the battery, the radio will sometimes come on with no prodding, other times it is required. No time frame that I can figure.
So you might get lucky and not need one.
Wayne
Old May 26, 2018 | 09:56 AM
For those who read about these cards and have never seen one .......
....... if the current owner of my 2001 XK8 has lost the card, this is the number you need!
Old Jun 1, 2018 | 12:15 PM
740i's Avatar
Default Might be worth a try
Here across the pond, we had a x-type and you could bypass the code with a few button presses after it’s locked you out. Google “x-type radio code bypass”. It worked on our little jag/ford. I have my code card for the XK thankfully. Failing that I’m sure the dealer network or give jaguar customer service an email. Good luck.
Old Jun 1, 2018 | 01:47 PM
Originally Posted by 740i
....Failing that I’m sure the dealer network or give jaguar customer service an email.
That certainly used to be the case. With VIN and proof of ownership, a dealer would lookup the code and rarely charge for it. Recently we've been getting reports on the forum that dealers claim they can no longer do this.
Old Jun 1, 2018 | 04:41 PM
Redline's Avatar
So that's what the radio code cards look like! I've disconnected the battery in my '05 X8 probably 3 dozen times in the past 1.5 years and have never had to punch in a radio code.
Instructions offered from the other side of the Pond:
Enter any code 3 times so that the display shows "PLEASE WAIT"
Simultaneously press ">>" "PTY" and "A.MEM". Should only take 2 or 3 seconds and the radio turns on.
(You must press all 3 buttons at the same time.)
Old Jun 15, 2018 | 05:42 PM
I did not need a code for my U.S. radio replacement, per Graham's post.
absoluteze
Apr 26, 2024 10:02 AM
chazaroo
Sep 17, 2020 04:09 AM
greverrr
Apr 24, 2013 03:45 AM
rand h
May 19, 2011 08:54 AM
