Replacement O-Ring for Radiator drain plug?
Old May 14, 2021 | 12:48 PM
Kuddlesworth's Avatar
Default Replacement O-Ring for Radiator drain plug?
ANyone know what O-Ring size to use for the drain plug on my radiator? THis is what it looks like, it's perished and leaking coolant a little. Imgur: The magic of the Internet
Old May 14, 2021 | 01:08 PM
Old May 14, 2021 | 11:18 PM
DavidYau's Avatar
Default Cheap and safer to replace old plastic peacock plug
With the age of our cars, it’s probably safer to, and cheap, to replace the plastic peacock entirely. Years of heat cycles will have caused embrittlement the plastic. Worst thing in the world is for this to break in the hole.
Check out post #17 in the thread below. Fellow forum member GD gave details of a $3 replacement part.
https://www.jaguarforums.com/forum/x...-drain-163692/
Old May 15, 2021 | 02:52 AM
I ordered a set of assorted O-Rings, if the plastic is brittle I will replace it as well. Thanks for the link. More Information for DORMAN 61138 (rockauto.com)
Old May 15, 2021 | 02:03 PM
Barry_Tucker's Avatar
i just replaced the rad plug with the Dorman part. exact fit , identical to the one I removed from my car my car
Old May 16, 2021 | 11:41 AM
Thanks I will buy that.
sklimii
Jul 17, 2019 06:22 AM
skinnypuppy_22
Oct 6, 2016 11:26 PM
Dan Bennett
May 17, 2013 03:18 PM
tcage
Jul 5, 2010 07:46 PM
tonysilverstone
Jun 22, 2007 10:47 AM
