Reprogram Key
Old Mar 17, 2010 | 11:14 AM
jnporcello's Avatar
Default Reprogram Key
One of my keys does not work in the ignition after the winter. Is there any way that I can program it with the two other keys? I have the valet key and one regular key that both work. It is the other standard key that doesn't work. It inserts into the ignition and turns, which illuminates the dash lights, but no engine turn over.
Oddly enough, I believe that this is the same key that did the same thing after picking the car up from some dealer service work last year. The dealer drove my car out with the valet key, but when I went to leave after having the service performed, the regular key wouldn't work - it did the same thing. I went in and told them and the tech reprogrammed it and had me on the road in well under 5 minutes. Is there a way to do it on my own? I know with many vehicles if you put the key in the ignition, turn to run, remove it, put the other key in, do the same, and then on the third time you can program a new key. Does anybody know if this method or any other will work for these?
If not, anyone have any clue if this would be covered under select edition warranty?
Thanks,
Nick
Old Mar 17, 2010 | 12:12 PM
H20boy's Avatar
I've not heard of keys losing their programming before, my guess is there's something wrong with the security module. Hopefully someone else will be able to assist you.
No, you cannot reprogram your own keys, only the remotes.
Old Mar 17, 2010 | 09:59 PM
motorcarman's Avatar
Thanks,
Nick
The procedure you state will work with the X200 (2000-2002MY S-Type) but not the X308 or X100
bob gauff
Old Mar 18, 2010 | 01:32 PM
jnporcello's Avatar
Anybody know if I can reprogram the key myself -- which would be best since the dealer is 1 1/2 hours away. Or if the select edition warranty covers key reprograming?
philwarner
28
Jul 11, 2017 10:21 AM
Listers
Sep 30, 2015 07:45 AM
JTC3400
Sep 29, 2015 05:03 PM
Jzar
Sep 27, 2015 02:55 PM
